TwinTurbo.NET: Nissan 300ZX forum - 1 is a tension rod bushing, replace both. 2-4 look like
Subject 1 is a tension rod bushing, replace both. 2-4 look like
Posted by thunderZ on October 08, 2003 at 11:36 PM
  This message has been viewed 81 times.
In Reply To leaks and joint problems..missing parts. argh. posted by maxl(Indy) on October 08, 2003 at 11:16 PM
Message a starter bolt, but I can't really tell. #5 could be from a few things. That's right under the oil line for the pass side turbo feed, and also the valve cover above it could be leaking. Clean it up and check again later.
